need advice on blow-thought set-up vortech
stanggt00
371
baltimore md
hey guys what all do i need to change my set-up to blow-throught
i have a vortech sq-trim
setting in my basement paxton fmic,vortech mini-bypass
if i get the pmas 75mm 3" and a retune is there anything else i will need to do this set-up
i am tring to finish up the motor side
8-rib vortech pulley kit
18% overdrive crank pulley from innovation west
2.75 8-rib pulley
16psi would be nice
-8 fuel line
fpdm stg 1 w/larger wires
that pulley and crank my over spin the blower alittle my redline will be moved up to 6500rpms .....then i am done with the more and will start on the body and paint for 2010
I am in the process of installing mine now. I had to modify my intake pipe going to the throttle body by installing a threaded hole for the iat. I got a lightning iat which is threaded. I have the Pro-m meter and didnt check the plug yet, cuase I know its wierd with some years having a buiilt in iat and some not. I think my meter has the built in iat, but I just wont use the function? Still learning that stuff haha. But other then that, sounds like you got what you need:nice:
