- Oct 20, 2004
- 1
- 0
- 0
HI EVERYONE
I would really appreciate it if someone could be of assistance. I own a 1994 Ford Mustang GT V8 5.0. I’ve modified the car with heads, intake, TB, 24lb injectors, mass air (calibrated for 24lb injectors), everything (no supercharger). I did keep the stock cam for drivability issues. The car ran great; I ran a diagnostic and no codes showed up.
Recently, the car started running pretty bad. I though it might be an ignition problem, so i changed the Ignition Control Module ( ICM ) with a JEGS unit. That wasn't the problem. I put it on a diagnostic machine, and received codes 157 (Mass Air Flow signal low or grounded), code 212 (Ignition TACH signal was erratic or SPOUT circuit fault) as well as 136 (oxygen sensor lean bank 1). Can you please inform me of how to resolve the issue with codes 157 and 212 and what do they mean? Why would the voltage be low?? I don’t know where to start. While the engine is idling, if I disconnect the Mass Air the engine begins to run better, if I reconnect the idle drops and runs bad. Do I need a new MAF?? BAP sensor?? PLEASE HELP !!!!!!!!
If you can help please email at [email protected]
thanks
thanks
