03-s281 said:
If I disconnect my battery to bolt up a UPR o/r x-pipe and do
the MIL elim is that gonna mess with the Saleen reflashed computer?
And is this a actual magnaflow catback on the car stock and will the o/r
bolt up to it?
Will I pick up good results from this? I definately want it louder.
ok first off, when i did mine i never diconected my battey
a. the O2 sensors will not be affected because siginal going to the 02 sensors isnt sending unless your car is on, and i hope you dont plan on trying this with u car on cause it isnt gonna work lol
b. you dont wanna lose you setting
ok now on to the x pipe no the mill elmintaors will not affect the saleen computer because
a. mill ellims, fool the computer into thinking that the rear 02 sensors are still active by resending the same siginal back to the computer thus fooling the computer and elimitaing the computer from throw a code
b. the Saleen computer works like all ecm's it can be fooled with the elli's
so just strap that pipe up connect the left side o2 sensor
on the right side ull need to do some trimming to the o2 sensor, ull have to cut the side tabs off so the ellin will fit
youll be amazed at the roar and gains are ok little bit maby
7hp 10lbs ft tourque
lots of noise
well worth a simple pipe swap
just my 2 cents good luck
