Engine Need Help With Valve Train
Jakethesnake95
So I got a 86 fox about a year ago with a 92 EFI roller motor and I'm rebuilding it and switching to carborated I pritymuch have everything done exsept for the valve train im looking and a set of heads with .550 max lift and the comp 35-302-8 and I'm thinking 1.6 stud rockers would that be cutting it to close with the springs? Also I couldn't find if it had the fuel pump lobe on it or not any help is appreciated.
  • Sponsors(?)
StangNet created a new car social app called knowmoto! Add your Mustang or post a photo in the knowmoto app and enter for a chance at a $100 gift card from LMR. Click the LMR Logo for more about the knowmoto Mega Thread!
mikestang63
SN Certified Technician
Aug 27, 2012
10,210
6,986
204
In the garage
That cam is for a Mass Air Car with 3.55 or 3.73 gears , not a carb. Also the exhaust lift is .534. Are you asking if .550 springs are strong enough? Depends on the spring and what type of cam. You always want to match the springs to the cam. I'd also check the PTV clearance.
Why are you going backward to a carb?
What heads are you looking at?
John Dirks Jr
there is enough sticking out to grab on to
5 Year Member
Jun 28, 2013
2,847
1,218
174
57
Maryland
This is a question from me related to this post. Does the 92 EFI block have an opening to install a mechanical fuel pump? I ask because the OP was wondering about the fuel pump lobe.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
36,114
12,035
224
Massachusetts
92 timing cover won't have the port for a mechanical fuel pump. You'll need a pre 86 cover for tyat
Sent from my big ass iPhone 6 using Tapatalk
