Had a Dyno Max Super Turbo cat back on my car when I bought it. Muffs were rotting so I removed them and kept the flow tubes and tails, and had straight pipes put in place of the muffs. With cats oon the car back then it sounded ok...
Now I have the off road X pipe, and a borrowed set flowmasters and flow tubes dumped at the axle. The straight pipes were waaay to loud and sounded like arss anyways, when the cats werent there.
SO. I have the stainless tails form the Dyo Max Super turbo system, what offsets do I need muffler wise? I can't remember if ther Super turbos were off set inlet / offset outlet, or offset inlet / center outlet.
Is it: offset inlet / center outlet? Or offset in / offset out? on the Dyno Max Super Turbo cat back kits?????
Thanks.
Thanks.
