• Community Forums
  • Regional Forums and Event Information
Need SMOG Help! Please!!!
  • Thread starter Thread starter 92greenlx
  • Start date Start date Sep 1, 2004
9
92greenlx
813
Ca
Sep 1, 2004
  • Sep 1, 2004
I failed the Test Only Smog Test last week. I failed the NO(ppm) part. Here where the results,
15mph Max is 785 and I got 1328
25mph Max is 724 and I got 730
So I put on a New IAC Valve, EGR Valve, O2 Sensors and backed the Timing Back to 10deg.
Well, today I went and had a pre test smog check done and here where those results,
NO(ppm)
15mph was 1073
25mph was 719
And my HC(ppm)
15mph Max is 114 and I got 191
25mph Max is 88 and I got 91
So I failed the 15 mph NO(ppm) and both parts of the HC(ppm) as to where the 1st time I passed the HC(ppm). I dont know what else to do except put back on the stokcer 4 cat h-pipe. Right now I have a 2 cat Mac high flow h-pipe. The shop I took the car to today did a diagnostic check on the car and found nothing wrong with it. They said it was highly moded and needed to be put back to stock form. They took only a look at my car and didnt want to figure out what was cauing my car to fail. What else can I do?
M8KMDAY
234
Oceanside, CA
Sep 2, 2004
  • Sep 2, 2004
Do you have a fpr and what is the pressure. It sounds like your are running to lean
9
92greenlx
813
Ca
Sep 3, 2004
  • Sep 3, 2004
No i dont have an adjustable fpr. So I am running at stock pressure.
ALMOST STOCK
1,250
41
88
CA.
Sep 5, 2004
  • Sep 5, 2004
Your dilemma sounds exactly (#'s and all on both of your pre test) like the same problem I had in May when I tried to mine smogged.
The technician who tested my car B] all 3 times [/B] has been doing testing for over 10 yrs and I've known him since he started in the business. He tried to do a few things such as changing the timing, idle, etc., to help me pass but no luck. After the first test he told me that he felt the cats were the problem (stock cat w/ 186K on them) and I needed new ones so he felt.
I changed the exact same things that you have and went back for my second test, same problem as you again.
I bought new catted exhaust system (Magnaflows X pipe w/ cats) and went for a third test. Yep you got it passed with flying colors.
As I said I’ve known the technician for over 10 yrs so he didn’t look at the Magnaflow system and his machine didn’t know the difference.
I'm not saying go out and buy new cats; all I'm saying is try putting on your old stock 4 catted system to see if you’ll pass instead of spending any more money.
9
92greenlx
813
Ca
Sep 5, 2004
  • Sep 5, 2004
Thanks for the info. I will post my results of the test once I put the stock h pipe back on.
ALMOST STOCK
1,250
41
88
CA.
Sep 5, 2004
  • Sep 5, 2004
I'll be looking forward to seeing your results.
I'm just curious to see if the cats were the problem.
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Oct 16, 2024
89ripper
A
Help with engine issues/emissions
  • Artyom
  • Apr 11, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 12, 2024
Mindseye007
P
Thoughts on this odd (smog legal) combo?
  • PJV9126
  • Feb 8, 2023
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 16, 2023
91AOD5.0LX
  • Community Forums
