Max Power said:Full vacuum poprt defeats the purpose of even using vacuum at all. You can just do the same thing mechanical.
Vacuum advance is meant to fine tune spark advance for optimum settings under certain load and throttle conditions. Running full manifold defeats that function.
In this case it works OK, becuase the owner can't be bothered to out the distributor in the roght location, but overall, that's not the most efficient use of spark advance.
Ummm, you are a little off with that statement. I jumped the wires to accomplish the EXACT same thing as resetting the distributor on the gear. Could the spark be more efficiently used? Of course. However, re-stabbing the distributor would have ZERO to do with it. I need to take the time to have someone put a full MSD ignition system in. For now, everything seems to work very well. How can you argue with that?
I timed it using ported vacuum advance. Still, if the initial was adequate for starting and idling, it would ping. If it wouldn't ping, it wouldn't start and idle and would get hot (not enough advance). That is why I went this way (full vacuum). The only thing I was "too lazy" to do was to have the distriubtor re-curved with 14 degrees advance initial and less total advance. This can be done either vacuum or mechanically.
With this (full vacuum) setup, I get max advance when I basically turn the key. The advance drops out as I get into the throttle to the point where it hits initial timing at WOT.
