  • 1994 - 1995 Specific Tech
new 331 combo
  • Thread starter Thread starter USMC1966
  • Start date Start date Dec 21, 2005
U
USMC1966
23
Jacksonville , NC
Dec 21, 2005
  • Dec 21, 2005
How's this sound for a new combo
331 9.5-1, Eagle crank, Eagle H-beam rods, Probe pistons, Vic Jr heads, Vic Jr.s intake, AMS B451 high rev cam, HO 750 AED, 1 3/4 Mac LTs, 3" X-pipe, Dumps, Compucar 175 shot, C4 w/ T/B, 3000 stall, 4.10's, 28x10.5 slicks
I still need to see how much the car weighs. But I'm hoping for low 10's
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 21, 2005
  • Dec 21, 2005
Up the compression and use a 347 rotating assembly and it sounds MUCH better. Why are you using an AFM blower cam with an n2o application?
94Blue302GT
704
Chicago
Dec 21, 2005
  • Dec 21, 2005
sounds good, but i'd rather the 331, the 347 has a pretty close stroke. I just hope this doesn't turn into a 331 to 347 debate.
I would go for 10.5:1 pistons.
I would also recommend rethinking the cam.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 21, 2005
  • Dec 21, 2005
With those parts I would go 347 for sure. Why skimp on the extra 14 cubes at this point. The price is basically the same.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 21, 2005
  • Dec 21, 2005
347-331 = 16
Go 347, more compression and a different cam. Then hold on
VibrantRedGT
424
154
Boca Raton, Florida
Dec 21, 2005
  • Dec 21, 2005
Type-O man. I sent you PM last week, you never responded. What fuel pressure you running?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 21, 2005
  • Dec 21, 2005
Joe, I never got a PM from you. I run 39psi vacuum off. I haven't touched my FP in a long time. All my fuel is through the PMS.
U
USMC1966
23
Jacksonville , NC
Dec 22, 2005
  • Dec 22, 2005
I'm trading some stuff around the house for it, so it's not costing me a thing except gas to go get it! The 72 block is already machined (I have the linked lifters). I can shave the heads to 58 cc get the compression up to 10.16-1 instead of the 9.8-1.
I might do a custom cam, but the cam is for N20 or a s/c.
B-451
N2O or S/C 10-20lb 331-347 c.i.d. Best performer for 6600-6800 rpm. Great with TFS TW or R's, Edelbrock RPM or Victor heads. Minimum 50lb injectors and 80mm to 92mm mass air. Recommended 3.73 to 4.10 gears, good drivability down to 2200 rpm, mild idle, rpm range 2800-6800, needs 3000-3200 converter. Must use AFM valve springs.
10's or what?
Black95GTS
1,644
Marlborough, MA
Dec 23, 2005
  • Dec 23, 2005
B-451
10's or what?
Yeah I think you will be in the 10's with that, providing:
1 - You manage to tune that monster. Not gonna be easy with 50lb injectors.
2 - You don't crack the block. You're lookin at 300+rwhp easily NA and around 500 with the hit. Thats asking for trouble with a stock block.
Adam
Pops Fun
961
14
59
Cincinnati, Ohio
Dec 23, 2005
#10
  • Dec 23, 2005
  • #10
Hi
If your thinking S/C lower compression is better... I have 10.1 compression and getting a S/C installed after Christmas... using Cosmetic extra thick gaskets .71 to get my compression down.... If you might want a S/C go with lower compression... maybe O-ring the heads and gaskets.
U
USMC1966
23
Jacksonville , NC
Dec 23, 2005
#11
  • Dec 23, 2005
  • #11
I have 300 rwhp from my 306, stock crank and rods w/ Ross pistons. Tuning isn't a problem I run A/F meters to get it close then take it to the dyno down the street.
I run a 750 D/P, so injector's are out, that's quoted from AMS.
The blower is out of the ? I have a dual stage nitrous system that can goes too 450 hp (w/ both shoots 225 each). So I can play w/ the HP levels. Spent allot of $$ to run a 2 1/2 fuel system just for the N2O and Carb.
I know the block is a time bomb! But with a safe tune it will last for a season.
Remember I'm trading for a short block. If it blows then cool! I can buy a Dart block and a 347.
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
C
New here. Was left a 67' Mustang 347. Ready to go down the rabbit hole but don't know where to start.
  • cmille198
  • Jun 29, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 12, 2023
AeroCoupe
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
72K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
