OK, I got the answer for my problem. I hope this could help others out there.
Just spoke to Chris owner/calibrator at Pro-M Racing. The problem I am having, is the "position" of the meter/sensor.
When Chris calibrates the meter, he uses the exact same cold air tubing. But, the problem is, there is no bracket to fix the Pro-M meter in my car, so it is in same exact position as when it's calibrated. I had the meter clocked too counter-clockwise or closer to 11'oclock. It has to be exactly level/12'oclock to get the precise air measurement. I clocked the meter a bit and the car runs smooth.
Chris also stated, the elbow on the BBK CAI causes air to flow heavier on the outside of the tube (closer to the engine). And, less air on the inside (closer to the fender). These older sensors have to be exactly dead center. One advantage...if I wanted to run a little richer, I can have the meter clocked clockwise a bit.
