New motor... Any estimates on HP?
I'm building a new 302 for my 88GT, its motor needs a rebuild badly, but but I can't be without a car while I rebuild it. So I'm building a new block. Specs are below, let me know if you have any guesses on what kind of RWHP it will make.
STD bore 302 block
Eagle "SIR" Lightweight Rods
SRP flat top forged pistons 10.1:1 compression
Total Seal Rings - Gapless second ring
Fully balanced rotating assembly
E303 Cam
Comp Cams 1.6 Pro Magnum Roller Rockers
AFR 185s with 58cc combustion chambers
Stock intake w/ ported lower
stock mass air and 19lb injectors
BBK ceramic coated shorties
Stock H-pipe
Flowmaster cat back
255lph fuel pump
MSD 6AL
MSD Billet Pro Distributer
MSD Blaster Coil
Future upgrade as money permits:
GT40 Intake
24lb injectors and Granatelli mass air sensor
BBK 70 mm, throttle body
Tremec 3550 or TKO
Thanks,
Craig
STD bore 302 block
E303 Cam
Stock H-pipe
Flowmaster cat back
255lph fuel pump
MSD 6AL
MSD Blaster Coil
GT40 Intake
Tremec 3550 or TKO
Thanks,
Craig
