Hello everyone.Im new to the forums and would just like to introduce myself and my car to everyone.Names Rich,feel free to email me anytime.
SN95 GTS
Tremec 3550 roadrace ver.
Richmond 373 rear end/steeda axle girdle
Aluminum driveshaft w/loops
Centerforce stg 2 clutch/ford racing flywheel
Pro 5.0 shifter
zr 275/40/17 rear 255/45/17 front
BBK Jet coated Shorty Headers
Mac H-Pipe(off road no cats)
40 series flows dumped at the mufflers
Frpp mass air and BBK throttlebody(75mm)
BBK Fendermount coldair intake
MSD 6aln ignition w/ C4 coil
12 degrees tdc w/7 stage retard to 27 degrees tdc @5200 rpm's
MSD Distributor-8455 pro billet
10.4mm taylor wires/still on motorcraft plugs
Venom 400 module(Yes it really works)
BBK underdrive pulleys /ac and smog pump eliminator kits
24 lb injectors/BBK fuel pressure regulator
BBK 255 lph in tank pump
Ive removed the backseat as well as all the foam from bumpers and body panels(Extremely noisy---But isnt that what we want
)Taken out all the noise dampening material in the interior panels and under the carpet.Removal of the smog pump and ac was a big help in the weight department.Removed the mach 460 and all components for it including all wiring.Several other small reductions that add up to alot have been done but too much to list.Basically,other than the sound and gauges,my car is a true sleeper.Ive kept the bone stock look throughout the whole car as much as possible.Im not really a track guy,I just love to dust the imports.
Next,Im looking into a tweecer first,suspension and then its time for some brakes!
Also,when are they gonna make a cornfuel mod for the stangs?
SN95 GTS
Pro 5.0 shifter
)Taken out all the noise dampening material in the interior panels and under the carpet.Removal of the smog pump and ac was a big help in the weight department.Removed the mach 460 and all components for it including all wiring.Several other small reductions that add up to alot have been done but too much to list.Basically,other than the sound and gauges,my car is a true sleeper.Ive kept the bone stock look throughout the whole car as much as possible.Im not really a track guy,I just love to dust the imports.Next,Im looking into a tweecer first,suspension and then its time for some brakes!
),but that initial launch is so important,that I dont want a full blown roadrace type set up.I need to find something in the middle,and I know nothing about suspension at all.
