NITTO 555R'S
agreed, the 555's were one of the best tires i had, until drilled the biggest pot-hole known to man... say hello to 2 new rims and Pirelli P Zero Nero's which now are the best tires i have ever ran.
I run 275/40R17 Nitto 555R Drag Radials on 17x9 Cobra R wheels. The difference between them and regular tires was night and day. I used to spin through second and could spin quite a bit into third if I shifted hard. First gear was usless. Now, I can nail it in first and it will just launch. They don't make the difference at the track they do on the street, but they hook hard. Also, if Nitto's spin a little, they will just dig in, while normal tires once they break loose, they don't recover.
I will put out a warning that these tires hydroplane easy. They are supposed to be the most streetable of the other drag radials, but make no mistake these were designed for dry roads. They will hook on the wet street, but once you get any speed, they hydropain. My car isn't a daily driver, and I don't think I would put them on a daily driver, some may dispute that but last night I got caught in the rain and had to drive 35mph the whole way back.
They only hydroplane easily if your driving faster than the conditions permit...or if you have wore out the treads.
Any tire is going to hyrdoplane at excessive speeds. Nitto's just happen to do it a bit easier.
I can clip along at 75mph in steady rain with no problems. In heavy rain, you shouldnt be going that fast no matter what tire you have.
I daily drive mine 30 miles one way to work, rain or shine. If your hydroplaneing, your driving to fast...plain and simple.
Andres2882 said:
Considering your running 275 40 17's, maybe you can answer this for me. Do lower profile tires hurt your hooking ability?
Yes, less sidewall won't allow the tire to squat down and get as much as a contact patch.
My buddy went from 315/35R17 BFG DR's on 17x11 ZR1 wheels to 265/60R15 Nitto 555 DR's on 15x10 Weld Pro-stars. The 265's are alot thinner, but he can hook so much harder.
I love my 555r Nittos, night and day difference on the street. Shifting hard into second is useless on street tires, these Nittos give a little bark if that's all i want and then hook, I can still break them loose but it's much harder to do than before i got them.
1990BLUEGT said:
Just a side note: make sure you get the 555r's and not the 555. The 555's get really hard after you don't "break them loose" once in a while. They also don't provide the performance you are looking for.
I second that; I have 245/40/18's out back and they're really not that impressive.
