Normal stock clutch life?
99SilverGT
1,660
Jacksonville, FL
Just curious... mine has about 75k on it and it seems to be starting to slip some. When I hit 2nd hard I hear a kind of short metallic squeek from under the car and the tires don't hardly even chirp... although the 285 Nittos don't help that. :D
Red2000GT said:
Depending on your driving style,50-100k is probably normal. The squeaking sounds to me like the throwout bearing on the tranny. It's a common problem with mustangs.
Doubt it, its only when I shift as fast and hard as I can into 2nd. Used to be able to get sideways, now I just hear that noise... and sounds more like metal on metal or ceramic on metal scraping. Its got to be the clutch starting to slip. I know the noise you speak of... and I hear that all the time while I'm just cruising in pretty much any gear. Sounds like 10000 crickets under the car... its not that.
BanginStang97GT said:
Mine's been beat to death and it still grabs almost 100 percent. Are you sure your belts not slipping?
Yea, can't be the belts because its preventing me from getting sideways in 2nd like I used to be able to. Its losing power to the wheels. Not to make it sound like I do this all the time either... I rarely ever do, just that the last couple times I've tried I heard that noise and the tires hardly even chirp.
im replacing mine this week with a spec stage 2....my car only has 14,000 miles on it but when ford does the fix on my 3650 i figure i might as well have them throw a new clutch in ....why throwout bearing is making some noise too
I have 80K miles on my stock clutch and it works great. Put about 40 track runs on it and no slipping yet. Most of the miles were highway driving.
The throw out bearing started chirping at 37K miles and still chirps.
