wow can u not find anything up to date? and btw yes paul is at harris and happens to be one of the most respected techs in the area, and btw the cobra well yea the fuel filter was never touched and dont know where they came up with that bs on it and the car being out of time is bs to bc it wouldnt have made over 625 at the wheels so tell me how a 03 cobra being a interfence motor is going to put down over 600 hp and be out of time thats a bs story and any body who knows anything about a mod motor will tell you so .
i see how you just point out the fuel filter but dont mention the umpteen million other things wrong with that car. I take it your paul from modular madness since you seem to be familiar with it.
So what about the k-member bolt hanging down, the fog light messed up, the dash lights on, steering wheel off 80deg, the fuel arm not connected
hell let me just copy and paste to help you out
As the car comes off the truck:
- Every dash light was on (theft, check engine, fuel, abs)
- Steering wheel was off 80 degrees.
- MGW Shifter handle (not the knob) was spinning around freely.
- Clutch pedal was nearly impossible to push in.
- Fog light was out
- Wideband gauge was not working.
First drive:.
- It was nosing over badly, bucking, backfiring. Had to rev it to 3K and slip the clutch just to get it moving.
- Vacuum was at 9-10 psi at idle and fuel pressure was 50+ at idle.
Next day:
- Took it to have it aligned and the brakes looked at.
- K member bolt was hanging on by a thread.
- A/C line was broken in two.
- Foglight connector broken
- ABS brackets were dangling behind the wheels.
- washers missing on k member- AC line was broken and had to be replace.
- Lock nut missing on clutch cable
- Bumper was dented/broken. Headlight support bracket broken.
Took it to the dyno to see what it was doing.
- completely cut out at 5300rpm
- So, as long as you kept the car between 3-5300 rpms, it ran.
Under the hood.
- wrong idler pulleys/broken bearing in idler (shipped with new BF black idlers installed)
- battery hold down and bolts missing
- bolts for coolant crossover tube missing
- Compression test showed 120psi on all cylinders
- Intake spacer installed with red stuff, leaking the whole way around.
Dropped the fuel tank.
- Sending unit arm was broken off and laying in the tank.
- Fuel filter was on backwards and clogged (not kidding!!)
- Bits of plastic shrink wrap (from the new pumps they installed) laying in bottom of tank with bare wires on the pumps.
- Focus pumps had focus socks, not the much larger 03 Cobra ones.
Got a new tune from a different tuner
- He read the tune that was on the car and was appalled. Said he'd never seen anything so messed up.
- New tune did not fix the backfiring/missing/hesitating, but finally got all the SES and dash lights to go away.
Decided to check the cam timing.
- Broken intake bolt
- Two torn intake gaskets
- Blown o-ring on crossover tube leaking coolant below the lower intake
- Cams were off by 1 tooth on both sides
- Car ran.idled a litte better but major problem still there.
Replaced a few more parts to try and track down the problem.
- Replaced ECM
- Installed 60lb injectors
- No change
Other stuff:
- None of my takeoff parts were returned (they were supposed to be shipped with the car)
- SCT handheld not used or returned. (they used a chip even though I wanted the car flashed)
- I was charged for a bad 02 sensor that went bad on their dyno while they were tuning my car.
- Got a COD notice from fedex for $1065 for the return of my stock parts. I refused the shipment.
- I have not paid the final invoice they sent the day the car was shipped. That invoice was for an ecm, pumps, dyno 02 sensor and plugs (sent new plugs with the car). Previous invoices for the other work/parts were paid in full by check (at their request).
