Optimas have lots of trouble moving around and the company became aware recently and have been manufacturing spacers that allow you to use your factory hold down clamps on them!87gtconv said:I just put it in my vert and the only problem was that the hold down clamp didnt really hold it down too well but it is usable. Eventually I will install the fancy billet battery tray I bought.
If you call the Company I dont see why they wouldnt send you the spacer out. Several guys on a Truck Forum I belong to were able to get some. One guy on there had his Optima slide foward and short out on the underside of his hood, it was a freakin mess, burned up evrerything!87gtconv said:Thanks for the info my first Optima only lasted 7 years wonder if that was the problem!! Will they give these spacers out to old customers with Stangs?? Although my new hold down will keep the battery motionless. I always thought that little thingy on the bottom was useless that Ford calls a hold down!
TheUser said:You will have to figure out something for spacing. I put a block of wood about an 1-1 1/2 inches thick in the front to keep it from squishing my overflow hose. Other than that, no clearance issues. I thought I had pics, but I can't find them, but here's the info:
Part Number: Red34/78
Model Number: 9083547
Cranking Amps: 980
Cold Cranking Amps: 800
RC (no idea what this is): 104...maybe recharge rate?
Price: ~$120 at pepboys
Wow that thing is awesome, might have to buy it when I move my Optima to the hatch. Thanks for the heads up.Sicarius428 said:I replaced my stocker with this one. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7968459098&category=33575 . It took a little fabrication but with an aluminum L bracket and piece of 1/4 aluminum that I found in my friend's shop, I mad a support for the inside(closer to the engine) from where the power steering hose support bolts to the frame. For the outsid by the fender, I drilled two holes through the sheet metal on the bottom and fed two bolts up through the bottom plate strait into the aluminum rods that hold down the top part. I had to throw the base on the mill to notch the inside corners(where the groove for the handle meets at the bottom of the battery) to be more square because my optima I think has a tad older style. Nothing that can't be fixed with a dremel though. It looks awsome and is solid. Just be careful when bolting the cables to the terminals. Cover the top hold down with something.
Kevin
