Ok, got more pics of perceived progress on the way. Multitasking is an understatement on this project.![]()
Currently working on harness routing. Good thing is none of it appears to be cut up. It was just routed everywhere it shouldn't be.
Meanwhile, I'm figuring out what everything is. But this part has me stumped. It hangs from the harness in the area behind the driver side headlight, somewhere near the washer fluid bottle. Has 7 wires harness plug but doesn't appear to go anywhere. What is it?
Well I'm undoing this crap, that's all I can say.
The dudes who did this can't be all that up on Foxbody wiring. They had the hood light plug (2 wire) jammed into the master cylinder low fluid sensor port which is 3 wires. They bent the friggin tabs over and everything! The correct brake indicator plug was found dangling above the fender skirt with the rest of the muffed up tuck job
That's the starter wire for the starter solenoid little post. How has that car been starting ? Does it have a newer mini starter with the solenoid on the starter body ?
To verify see if it gets power when the key is turned to start.....but that is the color of that wire...red with blue stripe....and that's where it comes from right by the coil.
