Hey all, been a long while since I've posted, however I'm in need of some advice and such. Anyhow, my NPI intake on my 98 GT was warped and needed to be replaced so I figured I'd go ahead and do a PI intake swap.
So I've done the swap and I'm in the testing for leaks phase and I'm having problems. I took the intake to a machine shop to have the 2nd hole drilled and tapped for the 2nd coolant sensor necessary on my car. They did a nice job as it looks factory and all. The damn thing leaks though, I've wrapped both senors with teflon thread tape, the one on the left side which is already tapped on the PI intake doesn't leak, perfectly fine.
The right side however does, so my dad and I figure we'll unscrew it retape it and use the RTV around it to prevent it from leaking, no good. We unscrew it again clean the area off, clean the threads off and then retape and put a little RTV around the threads and screw it in and put more RTV around it. Just got back from a little more aggresive driving, not WOT, and it's still busted through and leaking.
The only thing we're thinking of now is to use some JB Weld epoxy to pretty much cement the sumbitch in there. Curious if you guys have any ideas on wtf might be causing this thing to leak here. We of course let the RTV cure overnight every time we applied it as well.
We have a 2nd leak as well, it's a rather small leak that drips down onto the driveway at the back of the engine, around the bellhousing area I'd say, after the car has been driven around a bit. Was wondering if you guys have any ideas where this one might be coming from.
Have a 3rd leak which is the thermostat housing itself is leaking, we really just found this one now so I'm not too worried about it yet but figured I'd mention it.
Here's the other problem that I'm not liking either. When driving around today it felt really choppy. I'd try and get on it a little and it pretty much hesitated, shook a little(best way to describe it), just felt like the power wasn't there at all and if it was I was having to fight her to get going. Any ideas what might be causing this? Computer relearning? Another leak of some sort?
Anyhow I appreciate you guys taking the time to read this and help us out with whatever you have. Needless to say I'm both frustrated and disappointed at the same time.
The only thing we're thinking of now is to use some JB Weld epoxy to pretty much cement the sumbitch in there. Curious if you guys have any ideas on wtf might be causing this thing to leak here. We of course let the RTV cure overnight every time we applied it as well.We have a 2nd leak as well, it's a rather small leak that drips down onto the driveway at the back of the engine, around the bellhousing area I'd say, after the car has been driven around a bit. Was wondering if you guys have any ideas where this one might be coming from.
