opps i ment i'm going to go with the norm a 351 or find a mexican 302? peacesmittyb said:Bigger than a 460?
SMOKEDYA said:opps i ment i'm going to go with the norm a 351 or find a mexican 302? peace
john![]()
cubicgator said:wow a 101 stroked big block, hmmmmmmmmmmmm
that would be rather interesting.
98Snakebite said:Now that the notion of the 460 stuffed in a small, light, car is gone
I would say around mid to high 10's?74courier said:what kind of 1/4th mile times do you think i could net with a 460 with an intake, cam and some head work in a 2500lb car.
Why ya intrested in it? peace
this is what i was expecting also! but then after a little reserch and figuring i think it would be more of a hasel to swap it out every 2 years to get threw emisions? I could hit those times with a 302 you'd think? Or atleast with a 351 or if i dont sell it i'll hang on to it till i get a non emisions car? peacecubicgator said:iron heads, big cam, single 4 barrel, c-4, 3.55 gears 28/10 slick
10.25 to be exact! at 3000 lbs . hard to go 2500 with bigblock.
you could build a low 11 high ten car that would run on pump gas easy.
SMOKEDYA said:this is what i was expecting also! but then after a little reserch and figuring i think it would be more of a hasel to swap it out every 2 years to get threw emisions? I could hit those times with a 302 you'd think? Or atleast with a 351 or if i dont sell it i'll hang on to it till i get a non emisions car? peace
john![]()
352Ford2 said:you don't need smog legal stuff to pass the sniffer, just look at me
ddonaca351 said:A 460 (imho) will make the same power with a milder tune and there-for be EASIER to pass smog. IE: A 302 or 347, 393 whatever will need more cam, header, carb, etc... to reach a given power level than a 460 will, so it will have a harder time passing the sniffer test.
Heck a stock 460 can make 350hp and 450lb/ft all day long... try that with your stock 302.
All things in perspective....
DD
