that tb is way to big that thing will be a turd![]()
I was just about to say that, you won't have any "low end grunt." Also, your heads, intake, and cam are way t0o big. You should switch to a 55mm throttle body from a 5.0 thunder bird to increase velocity.
Adam
Adam
Interesting .. I did not know the TB had so much influence over the low end. Does it?
Also, he needs those huge parts to make that upper end power from a 331. He's not going for low end.
Wow.............
I'll put these ideas into consideration you two.![]()
They are being sarcastic.
And there will be videos.
Sound's Sweet!Nothing better than a healthy cam
Do you have a clip of it warm at whatever idle you are using?
What are the spec's on your cam?
