piston bore clearance?
ashford
485
fargo ND
i just bought a 347 kit and got the block back from the machinist. looking at the specs from kb piston bore clearance should be .0015-.002. when i went to install a ringless piston to check clearances i can fit a .005 feeler gauge between the piston skirt and bore. i gave them the pistons and the spec sheet to them and told them what it should be at. is this acceptable or should i get grumpy with the machinist?
Well, I think that you would check this by trying to insert a .002 - .003" feeler on each side of the piston (180 degrees opposed) as you are, I think, doubling the clearance by having the side opposite your .005" feeler against the cylinder wall. Is that right? I believe that there is a specific spot on the piston where clearance is checked. I don't remember if it is done at the skirt, or somewhere else. I didn't check my machine shop's work, so you are doing more than I did. Good going.
Okay, checked up on this, and it IS checked at the skirt, at the level of the balance pad.
i would talk to the machinist and find out why he set the clearances at .005 rather than .0015. and then let him know that he owes you for a set of pistons, or he can sleeve the block and set the clearances right for you. either way he needs to fix this.
some further checking i see that all the pistons are dead on the same, using the same hole. when checking them i put them i upside down and measure at the center of the skirt. .005 passes easily the whole length of the feeler gauge on all holes, and .006 will fit tight in a few of them. maybee tomorrow ill be calm enough to talk with the machinist with a straight head.
well i ended up pulling the engine out of my old mans beater and replaced it with my 302 the stroker will be replacing. i took this block to a different machinist and told him what happened. he told me not to worry he'll take his time and get it dead on. it took about 2 weeks for him to get it done, but hell he got it right. i didnt even need to measure to tell, i just put a piston in and felt so much tighter just a little bit of rock to it no slop. .0015 feeler gauge snug in most .002 tight.
