Please help, Front Brakes are locking up
  • Thread starter Thread starter Black1987Stang
  • Start date Start date Dec 13, 2006
Black1987Stang
1,422
Jersey Shore
Dec 13, 2006
  • Dec 13, 2006
Im thinking it might be the proportioning valve or maybe the master cylinder....this is how it happens, brakes are all fine for normal braking applications, but once you press them harder say for slowing down harder than normal the front brakes LOCK UP, if u drive around (well move forward slowly lol) for a little bit it will free up and be normal again......BTW its on a 79 Bronco with a 351 Modified....I no I no its not a mustang but at least its a Ford with a good motor .....What could it be? :SNSign:
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Dec 13, 2006
  • Dec 13, 2006
are the back brakes adjusted properly? if they are than its probably a metering valve problem or a proportioning valve problem. more than likely its happening because your rear brakes either arent working properly or the metering valve isnt keeping pressure off the front brakes until a certain amount of pressure builds up in the rear brakes....thats what im thinking at any rate
Black1987Stang
1,422
Jersey Shore
Dec 13, 2006
  • Dec 13, 2006
I gotcha where is the metering valve located?
HISSIN50
34
129
Dec 13, 2006
  • Dec 13, 2006
It can also be a damaged caliper (piston/bore relationship or a piston seal issue).
Good luck.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Dec 13, 2006
  • Dec 13, 2006
Good luck.
i would think its more of a master cylinder issue than a caliper issue. maybe the master cylinder is bypassing at a short travel and than when you really hit the brakes it applies full pressure. if it was a caliper i feel it would just drag all the time and not lock the brakes up and than get better. but it could be a caliper issue if the piston is seizing up and than breaking loose.
to the original poster....the metering valve should be in the lines right off the master cylinder.....i know on my car its the same unit as the proportioning valve
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 14, 2006
  • Dec 14, 2006
On cars with old rubber brake lines, the lines will seperate inside and cause a one way check valve effect. You step on the brakes hard and the fluid gets trapped inside the line and does not return to the M/C like it should. Since the check valve effect isn't perfect, the lines will loose pressure and gradually return to normal. Envision it like a balloon that swells up and pinches the center part of the line closed.
bt15
129
Oahu
Dec 15, 2006
  • Dec 15, 2006
Jrichker's description is not just something you can picture in your mind's eye. My old 88 Bronco began to exhibit similar symptoms to your truck, and when I crawled down for the old "visual inspection," one of the brake lines actually had a clearly visible pregnancy on it. I replaced both lines just to be safe - problem solved.
A bad master cylinder and a hanging caliper each manifested similarly on my truck, so take a peek. Man, that Bronco of mine ATE brakes - I was always working on them, repacing pads, calipers, lines, master cylinder, slave cylinders, etc.
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Dec 15, 2006
  • Dec 15, 2006
Sounds like a bad line or a bad caliper to me. If it was the M/C, it would drop w/o any brake pressure.
tbovee
129
Fredericksburg Va
Dec 17, 2006
  • Dec 17, 2006
I too would have to go with the hanging caliper or bad hose. I see it all of the time at the shop.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
F
Rear Drum Brakes
  • Fri Guy
  • Jan 3, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2025
Scrapla347
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
