Finally got everything back together and drove it alittle. Still have some damn weld leaks on the cross over, so il have to get on those.. But my main problem is...
Real bad break up, sputtering, cutting out, ect.. at WOT, from about 3000-3200up.. Right around where i hit full boost.
Plugs are Autolite 23's gapped at .28
Using the stock timing tables
stock fuel tables
base fuel presure 35psi ( 1:1 regulator)
10psi of boost
42lb injectors 255 pump
MSD coil
stock ignition
I never had this problem before, and to be honest im not sure where to take it. I know its easy to say i need a real ignition on it, and a fuel system, ect.. But i dont think thats the problem here, because when i dynoed near 500 horse last time, i had not a problem, except richness..
Can running to lean cause this? I am not noticing black smoke at WOT like i used to.. Maybe the EEC just needs time to adapt?
stock fuel tables
10psi of boost
MSD coil
stock ignition
