Okay, I'm looking for 300HP, any estimates on this configuration: Cobra upper and lower intake, 24# injectors (do I need a bigger fuel pump? I should probably go with a adjustable Fuel Pressure Regulator, right? Aeromotive good?) 70mm Throttle Body, 70mm EGR Spacer, 70mm Cobra MAF, Underdrive pulleys, 3G 160 Amp, (do I need an electric fan?) MSD 6AL ignition, MSD Blaster Coil, Bosh plugs/wiring (is a different distributor necessary, or should my stock one hold up? If so, what about just an MSD cap?), BBK intake, MAC longtubes, MAC offroad X pipe, flowmaster cat-back exhaust. 3.55 gears as well...
Right now I have a very small head gasket leak, so I'd replace that as well...
This is goin' on my 88 Vert (subframe connectors will be on)
That should get me 300HP right?
Sorry to ask this, I know it's a freqent topic, but I wanna get my excel spreadsheet done so I can start checking off the parts (to make me feel that much closer to my goal)
Thanks agian for all your help, you guys rock!
(PS: if your rock/blues fans, check out the band Tony C. and the Truth, their first single is called "A Little Bit More" they're quite good!)
Sorry to ask this, I know it's a freqent topic, but I wanna get my excel spreadsheet done so I can start checking off the parts (to make me feel that much closer to my goal)Thanks agian for all your help, you guys rock!
