Hello my name is Ryan and im in a big panic right now. I just got done doing a trany in my 2000 mustang GT. I did the whole 9 yards, including, new refurbished T-45 transmission, Spec stage 3 clutch, spec aluminum flywheel, FRPP aluminum driveshaft, energy suspension trany mount and motor mounts, And a Steeda adjustable clutch cable,double hook quadrant, and firewall adjuster. The trany fluid i use was BG Syncroshift2...very exspensive i might add. My problem i am having is when the car is in neutral and the clutch is enguaged there is a ticking coming from the clutch/bellhousing area and as soon as i push the pedal in just a 1/2 inch in the noise goes away. And it sometimes does it when the car is driving but not all the time, or if iv been driving a while... I have the cable on the hook the closest to the firewall cause im using the adjustable cable with the double hook quadrant. The thing i think i have messed up is the firewall adjuster is all the way tightened down as close as it will go to the firewall, and the the cable is adjusted pretty far on the adjutable rod...a little more than half way on the rod. Am i supposed to have the adjuster halfway out and the nuts on the cable not tightened so far? I got confused as to what a "light" tension on the cable might be. Its adjusted to where the cable is "light" on the clutch fork but when you barely press the clutch fork with your hand it jiggles around freely. Is this to loose? Also the clutch enguages really high on the pedal. Iv only drivin the car 68 miles since the install so it should be correctable and be fine to adjust to the right setting. Any help you guys/gals can give me would be GREATLY appreciated! I spent about 2700$ fixing my car and cant afford to fix it again if something goes wrong...on a tight budget...And thanks again
