Hey guys, here the scenario.
My entire mod list is in my sig. Im running the base sc-trim vortech kit with the fmu and stock injectors.
Before I put the SC-Trim on my car, the mufflers would seen to crackle and pop every now and then. Now that the SC is on there, its almost a completly constant "popcorn" sound coming from my flowmasters. This only happens when coasting in gear (usually after getting on the throttle a bit). For the first time a couple days ago the car backfired pretty hard while I was just coasting around 30mph.
If it matters, I put my car up on the car lift the other day to take a glance of the underside and noticed my tailpipes are pretty badly rusted through about an inch after the flowmasters. If that matters at all for this problem.
Anyways, I know everyone is going to give me "you need a tune" speech but you can go ahead and by-pass that because I already have that on the backburner I just want to go and get my maf/injectors/tb before I take it to the dyno.
With all that said, does anyone know what would be causing this to happen? Im thinking the FMU is making the car run just pig rich and excess fuel is just kinda burning off in my exhaust, but im not sure if that is totally possible. I know that is what a backfire is, but what is making this popping noise? Anyone opinons, suggestions, or insights would be greatly appreciated! Thank You!
-Adam
-Adam
They were on there when I bought the car. The tailpipes have rusted through some bit right after the mufflers so one could probably guess they have some age on them. But either way, would old mufflers pop normally? And would the SC increase this?
