Ported E7's or Ported GT40's?
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
On my hotrod now i have some ported fairly well E7's.. its strong as hell like it is.. in my garage i have a set of GT40's almost ported as welll.. porting was stopped due to a slight crack in the head that might be able to be repaired.. question is.. is it worth it to swap em out? I'd have to pull my crane springs and everything off again.. not sure if i should or shouldnt if all im going to see is like 5 hp increase.. thanks
my friend recently did a head swap on his car
he went from milled e7s with a valve job to some ported gt40ps.
he already had a cam before.
the car seems to have a little more lowend with the e7s which is good for the street.
with the gt40ps a little low end was lost a bit. But good gains in the high end.
His car pulls all the way to the rev limiter, the bigger valves really help it scream. I think the biggest difference is that the car will pull hard way in the upper rpms.
