  • 1994 - 1995 Specific Tech
Power Elbow
  • Thread starter Thread starter 94Blue302GT
  • Start date Start date Jan 18, 2006
94Blue302GT
704
Chicago
Jan 18, 2006
  • Jan 18, 2006
I have a turbo, and a somewhat custom intake, you can search my name for my completed turbo setup.
As you can see, the intake isn't that great.
I was thinking of using a power elbow on a good carb intake, but then how will it bolt up with my sn95 tb? I could do the fox conversion, but I don't have smog, so will it matter all that much? Is it all just the sensor, or is it a totally different setup?
Thanks guys.
84convertablegt
589
Columbus, OH
Jan 18, 2006
  • Jan 18, 2006
different throttle cable and bracket, different tps, different iac motor but same plug, different throttle body, but id recommend it for you with a nice fat 80mm throttle body. im assuming you dont have egr or anything so no issue there. the main thing is the throttle cable, u need one from a 86-93 car.
94Blue302GT
704
Chicago
Jan 18, 2006
  • Jan 18, 2006
can't you just change the end on the cable and bracket?
Do you still need a different tps and iac, even if the plug is the same? Do i need to swap the sn to the fox stuff then, or take the fox stuff. The cable I can play with, no problem.
84convertablegt
589
Columbus, OH
Jan 18, 2006
  • Jan 18, 2006
just use fox stuff, the cables are completely different though. it would take a lot to modify a sn cable vs. just getting a fox cable. the connectiion on a foxbody cable uses a snap on connector and an intergrated spring completely unlike the sn cable.
SWYZ721
208
Ann Arbor, MI
Jan 19, 2006
  • Jan 19, 2006
"POWER ELBOW" sounds funny
had too....
94Blue302GT
704
Chicago
Jan 20, 2006
  • Jan 20, 2006
hmmm, and i can't use my sn95 one on the elbow? Are they the same bolt pattern?
84convertablegt
589
Columbus, OH
Jan 21, 2006
  • Jan 21, 2006
not on a power elbow. the bolt pattern of a fox body tb and a sn95 tb is different. th sn is slightly wider with the bolt holes, but i bet you could widen up the bolt holes and make things work. maybe even keep the sn95 throttle bracket, but i dont know how youd mount it. just an idea.
94Blue302GT
704
Chicago
Jan 21, 2006
  • Jan 21, 2006
Ok, so i'd have enough room to slot it for the SN95? That would be cool. As for the bracket, not a problem, i'm pretty good for manufacturing...
Check out my current intake on post number 8.
http://forums.stangnet.com/showthread.php?t=604324
I'm pretty sure i can fab something up...
94Blue302GT
704
Chicago
Jan 21, 2006
  • Jan 21, 2006
Oh, and I'd just get a decent flowing lower, and probably port and polish it up real nice. May actually have one in one of my buddies garages..., but then of course i'd have to put in the bungs, which he's done before already and has running on a 351 cleve.
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
