power failure
93killerbee
44
ohio
searched threads and no help. I am haveing power failure under hard ecceleration. Replaced plugs. wires are good. what else could it be? mods are upper/lowerer intake, headers pulleys, h-pipe 70mm throttle body and egr. do i need bigger injectors, bigger fuel pump and regulater? im kinda lost, and is makeing me angery. Oh i just cleaned the maf senser and still no luck. Please help Thanks
yep, you need to isolate it more. it could be fuel, ignition or anything else. have you pulled codes?
i would play with a fuel pressure gauge. see if you are losing pressure at higher RPM's....does it do it while idling or just under load. have you run with this set up before, and did the car run ok?
you are not running platinum plugs?
as ECU said, for TPS check: connect a DMM to the ground wire and return line. based on your problem, i would sweep the throttle through the range of motion. do the volts go up is a clean sweep or are there breaks? base should be under 1.0 volt. WOT is about 4.5 volts (normally +/- 10%). make sure your voltage does not take a poo at WOT.
that is all that comes to mind.
good luck.
