  • SN95 4.6L Mustang Tech
Probaly the worst tech thread ever.
  • Thread starter Thread starter BurningRubber
  • Start date Start date Nov 3, 2006
BurningRubber
1,865
24
58
Nov 3, 2006
  • Nov 3, 2006
And I feel like a tard for asking this, but how the hell am I suppose to get the taillights off? The middle bulb in the right side taillight is out, and I need to replace it. I looked, and saw like 4 bolts holding it on, so I unbolted them, tugged... nada. There is also a peice of rubber that seals the water and stuff out of the lights with a wire running into it... I took that out, and unplugged the wire and still nothing. The only other thing I notice is that there is a stud or something that bolted down very tight (not with a bolt either, looks like a washer) and I dont see what else is holding it on aside from that.
So someone please, school the dumbass on taillight removal 101... its like they make the easy stuff hard, and the hard stuff easy on these things.
DTNODYA
831
  • Nov 3, 2006
I would also like to know ... I tried a few weeks back to take them off and got so frustrated I almost started breaking **** ... gave up.
Ford Service CD says:
Removal
1. Open luggage compartment door and remove luggage compartment rear trim panel to gain access to four nuts retaining rear lamp.
2. Remove four nuts retaining rear lamp to body and remove from vehicle.
3. Disconnect lamp socket and wiring from rear lamp.
4. If lamp socket and wiring is to be removed, disconnect harness connector in luggage compartment.
5. Pull wiring grommet from body and guide lamp socket and wiringthrough opening in rear body panel.
four six
506
Hobart, IN
Nov 3, 2006
  • Nov 3, 2006
Someone with those ugly euro lights proably will know
BurningRubber
1,865
24
58
Nov 3, 2006
  • Nov 3, 2006
Thats pretty much what I did, didnt budge. What a PITA.
Rickyll7
718
  • Nov 3, 2006
The studs on the lamp housing can get sort of "stuck" on the sheet metal holes they run through. You just have to work with it, it will come out with a little tlc. If you just want to replace a bulb, you do not have to remove the tail light. just twist the part what plugs into the back of the tail light, there should be three, and pull it out. it need to be rotated counterclockwise, i think, about 20-40 degrees. then it just comes out, like a medicine bottle top.
04GTMustang
348
Stafford
Nov 3, 2006
  • Nov 3, 2006
Rickyll7
718
  • Nov 3, 2006
LOL, no, I dont have those ugly euro lights. But I did have someone crack one of my lights a while back while the car was parked. Damn hit and runs...
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Nov 3, 2006
  • Nov 3, 2006
I think there might be 4 or 5 bolts to take off. They are goldish color if I remember right. just take them off and should pull right out.
fastangboi
My first set of nuts vibrated themselves off.
Jul 26, 2006
274
Slowville
Nov 3, 2006
  • Nov 3, 2006
there are these wierd thin little washers on the back side of those nuts that sometimes dont stay with the nut. That will make it super difficult to take them off. I hit the stud a few good times with a hammer. didnt hurt anything at all.
Matt's 03 GT
Orange County
Nov 3, 2006
#10
  • Nov 3, 2006
  • #10
I had to pull some rubber "body plugs" to access all of the bolts on my '03. Maybe you just missed a nut or two... I know I did!!!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 3, 2006
#11
  • Nov 3, 2006
  • #11
Euro tail lights FTMFL
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
