with this kirban style fuel pressure regulator that I have ( had it for quite some time), where would I tap in for the electric fuel pressure gauge that's going inside the car? I have a fp gauge at the fuel rails under the hood and don't see where on the fp regulator that I would tap in.It should not be directly inline with another bung. You can move it past the connection too, if necessary.
edit: disregard I will just remove the gauge at the fuel rail and put the sender there.
I do have another question about the boost gauge though. I've read do not use the plastic line that comes with the gauge but instead rubber or braided. It seems a lot use rubber and that's what I'll use. The pic is just in ref to my question about which brass nipple to use to connect? I saw an old thread from 2012 where a few said to use a brass nipple and with a barb.
Curious if the I.D. of the hose has to be the same as the plastic hose, looking at the inside of the stud on back of the gauge?
