I am pulling the 5.0 out of my 89 and leaving the AOD in it for now. I have most everything apart, I have loosened up the 6 bolts I found that I believe hold the AOD to the block.
1. Are there only 6 bolts?
2. Do I have to remove the starter? I have removed the cable/wire? So will the starter just stay on the AOD?
3. I still need to disconnect the 3 cables from the bottom of the throttle body. I have the bracket towards the firewall loose but how do I actually disconnect the forward end of the 3 cables. There are some plastic clip type things and I don't want to break them as they may be brittle from age. How exactly do they come off?
Thanks
Thanks
