Ok this is a bit long. I need to put a cam in because I had a FRPP roller lifter break and I'm sure damaged the cam. The stock one is still there. I'm not going to be doing any more mods to this and infact will sell the car next year for a new 2007. I'm between the e-cam and the TF Stage 1. Will I run into piston to valve clearance with the stage one with the stock block? I have the following mods. Thanks for you help.
Stock Block
C&l 76mm cal'd 19lb
70mm TB
Cobra Intake
19lb injectors
GT40Y303 heads
FP regulator
Mac ProChamber
Mac Flowpath catback
190lb fuel pump
3.73 gears
Stock Block
C&l 76mm cal'd 19lb
70mm TB
Cobra Intake
19lb injectors
GT40Y303 heads
FP regulator
Mac ProChamber
190lb fuel pump
3.73 gears
