Q. on spindle/hub grease seal
MustangLX-5.0
856
Lehigh Acres Fla.
I've had the front end of this car sitting apart for months now.Getting most of it back together but am stuck partly on the spindle/rotor assembly.I don't know if I accidently threw any non trash parts away or just lost them......to the point...How many grease seals go on or behind the hub/rotor? Are there any seals behind the brake dust shield or is it just that piece of foam backing? I assume there is only 1 seal in front of the dust shield..then the rotor with rear bearing attached into race...then front bearing..washer..nut..nut cap...then cotter pin.Is this the correct list or am I missing 1 seal somewhere? I ask this because the Haynes manual shows 2 seals on the spindle.And I dont see one lying around that looks like the 2nd seal in diagram.
