Question (Non Roller Block)
bc86fiveoh
I've searched but did not locate anything to my specific question.
I consider myself mechanically inclined but I've never built a motor (I've done just about everything else) so I'm about to try my hand at it.
I'm wanting to get about 300 to 350 hp on a carbed set up. Not for racing just to have it my stang. Is this an acceptable hp for an older 2 bolt main 302 block or would it be pushing the limits (strength of the block). In the search there were comments on the stock block being weak others that stated it was plenty strong. Also, I'm still researching the set up that I want but would there be any prob to using the stock crank?
Thanks
Thanks
the rule of thumb is that the stock block is safe up to 450rwhp....you will be more than fine with 350 :nice: . You will also be fine with the stock crank :cheers:
