Im only up to date on the late model 4.6's. I have no knowledge WHAT SO EVER about 5.0s. Im currently looking to buy an 87-93 5.0 5spd. First off my goals are to start off with a quick light to light car but also be able be my 100mi weekly driver. I would also like to go to the track sometime to see what thats all about. Eventually I would like to end up with an low 11sec car and a quick street racing sleeper car. I wont ever have a turbo or nitrous. I would like to have a nice N/A set up first then get the motor built and then add a supercharger. Only want to be able to run off pump gas. My questions are:
What do they run in the 1/4 stock?
How much do they weigh stock?
What parts are good to lower my weight on the car?
What is the ideal gear ratio for a N/A set up?
What is the ideal gear ratio for a Supercharged set up?
Can these motors have 300rwhp on the stock 5.0 and still be N/A?
What size rearend do they have?
What spline are the axles?
What kind of transmission comes in the 5spd?
What type of exhaust set up is the best for hp gains?
Which midpipe sounds better x or h?
What cat back sounds best?
How well do the trannmissions hold up?
What are the best mods to start off with?
What is the power limit for the stock bottom end?
What kind of regular maintenance is needed to keep them running strong?
How can you tell if they are ragged out?
How much does it cost to go from a stock 5.0 to a 250-300rw N/A motor?
What is the biggest rim and tire you can fit without any issues on a stock car?
What are the best suspension mods?
If I build a high horsepower n/a built motor with a blower on top of that at 15+ psi can I acheive 500rw+?
Im sure there are many more questions but I too tired to go on. If you have any other helpful input please list the suggestions.
