Quick question about 94-95 heads on a 90-93' any major differences?
Pokageek
2,767
MA, USA
I am selling my rebuild E7 ported heads cheap. I think the only difference may be the 2 smog pump holes. Those holes can be easily plugged. I also have shimmed springs made for the b-cam that I had. If someone is using them with a stock cam, will it hurt anything? I am thinking no, just that it will handle a bigger cam. Thanks guys! :hail2:
"I havent had any problems finding parts for my car... Heads, cam, intake, rockers, pushrods, yadda yadda are all the same in the fox 5.0's and the SN95" - 1105
Did the search. Doesn't look like I can find any differences that would affect install.
The casting number denotes that the heads were designed in the mid eighties, and cast from molds built in '87. The heads off any Windsor based small block will interchange from the early 60s thru the latest aftermarket stuff, with differences in the rocker arm design the biggest single difference. Should be no changes for any 5.0 HO from 87-95.
Scott
