really bad mpg. 40miles on 1/2 tank
fuzymealchosen1
41
ok. i am at a little more than 40 miles and a little more than half tank. its a 1993 5.0 manual trans.
cam
bbk intake
mac headers
no cats
flowmasters
4.10 gears
new o2 sensors (didnt help)
and some igniton stuff.i dunno its a red box but its not stock.
so anybody know how i can get better mpg? i was researching and people are getting like 20 mpg with similar setup.
any thing that you guys think the problem could be?
you need to check for codes first and foremost, what everyone else will tell you to do also.
when fuel gauges go bad, they usually just peg out at full in my experience. when its nearly completely out of gas, it will drop to E out of nowhere.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Removing the smog equipment does not make the car run faster. All the pollution control equipment shuts off at full throttle. Removing the pollution control equipment just makes the computer mad and spit codes. Removing the Thermactor Air pump (smog pump) or disabling it on a car with catalytic converters can cause the cat converters to clog and choke!
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
It's about $25-$35 from Borders.com see Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more . Select books and then select search. Use the ISBN number (without dashes or spaces) to do a search
Use the ISBN number and your local library can get you a loaner copy for free. Only thing is you are limited to keeping the book for two weeks. It is very good, and I found it to be very helpful.
If you need some help with your automotive electrical skills, try Automotive Online Instruction for a beginning course. The course is very good and best of all, it is FREE!!!
