It's been like this for the last month. I've had my cobra for only about four months now and when I had first got ahold of it, I knew the pads needed changing. After buying a (generic?) set of pads from autozone and turning both front and rear rotors then replacing all the pads, I've had this "clunking" that I can't get rid of from the front brakes. Since then, i've replaced the pins, all screw hardware and double checked the rotors for freeplay, but the D*mned things are still loose. I need someone to listen to it while driving down the road because feeling around isn't narrowing it down at all. Anyone else ran into this problem with the solution?
Also, I was told from autozone that brake rebuild kits don't exist because the car is too "new". Sounds like they just didn't have the kit at all.
