Rear 8.8 axle bushings...which ones
Mustang5L5
Mod Dude
Feb 18, 2001
43,309
18,021
224
Massachusetts
Hey guys, redoing my 8.8 axle. I'm going to replace the two top bushings. My question is what's a good set to go with for a street car with emphasis on handling? I want a nice tight ride, but no noise or extreme harshness.
What's good to go with? :shrug:
If you are talking about the uppers on the diff I'd go with the rubber ones for the later models that you can get from Ford or Maximum Motorsports. They will work nicely. Don't forget the removal/install kit Maximum sells for them or make your own. It will make replacing them much easier.
I just ordered stock replacements from AutoZone..( I know, I hate Autozone, but they stocked them) They were cheap and my car rides really nice, no noise at all.
A friend bought some all aluminum hyme joints or whatever they were, and he tore the **** out of his torqu boxes. Car rode terrible before that also....don't go that route.
When i replaced my rear LCA's- I went MM lowers and cobra upper arms and ford racing bushings. (your right) I replaced the quads as well. The car is super tight today, it was a good choice. The upper bushings are stiffer than stock fox bushings.
I think i may go with that exact same setup myself
You won't be dissappointed. I installed a set of typical upper and lower arms with the poly bushings and the car was down right dangerous to drive. Snap oversteer is scary stuff.
I pulled that stuff out and replaced it with the MM lowers with shperical bushings in the lowers and the ford "stock" arms up top. At the same time I replaced the axle side bushings with rubber units from MM. These are just factory replacements. No more snap oversteer but the road noise is increased from the solid "bushings" in the lower arms.
