just curious. i've heard people saying to take it out as a free mod. what does it do? does it give you 20hp? J/K
MSTANG said:Actually I've heard it's detrimental b/c it "straighten's" out the airflow in the meter to make it more accurate
You ever get the control arm situation squared away?
i'm going to mess with the control arms again anyway. i ordered all new bolts, so i'm going to replace them, install my upper poly bushings and readjust the pinion angle. but yes, i had it situated. axeman said:yeah, but i haven't really driven it yet because i basically ripped right into working on the rear. somehow i must have switched the axles and now my passenger side tire rubs the inner fender again. damn axles must not be the same length, go figure.i'm going to mess with the control arms again anyway. i ordered all new bolts, so i'm going to replace them, install my upper poly bushings and readjust the pinion angle. but yes, i had it situated.
sounds like i'll gain nothing by removing the screen, maybe actually hurt me huh?
I always thought in mustangs they were the same length
Glad you got it ironed out now you just gotta swap the axles back
MSTANG said:Yeah I'd leave the screen alone if it were myself.
Strange...I always thought in mustangs they were the same length
stang22 said:What about all of the aftermarket MAF's that don't come with a screen? Will airflow be affected if they don't come with one.![]()
axeman said:just curious. i've heard people saying to take it out as a free mod. what does it do? does it give you 20hp? J/K
axeman said:i don't get it either
MustangGroupie said:I'll meet you at the track and you can borrow my meter, calibrated for 24# though, probably wont work? I wanna see yah in the 12's because I know if you can run a 12.9 when I swap in my tremec I'll be running 12.0's
i'm hoping my times drop significantly next friday though. i'm also thinking of getting a dyno tune done soon. one can only benefit from that. would also like to get a mass air meter and throttle body.axeman said:thanks, but no it won't work. i didn't say i was going to run a 12.9 the next time i went to the track, but hopefully soon.i'm hoping my times drop significantly next friday though. i'm also thinking of getting a dyno tune done soon. one can only benefit from that. would also like to get a mass air meter and throttle body.
If Its nice ill bring my beast out and see what she can do, be there rooting for yah!MustangGroupie said:The maf is set up completely different, mine monitors the air flowoing through only a portion of the meter, then makes it's adjutments from there.
