93CalypsoConvert Active Member Nov 26, 2020 267 80 38 Virginia Mar 15, 2023 #21 Mar 15, 2023 #21 Picked up a new booster. That was no fun installing it It did fix my problem though! I can lock all four. Last edited: Mar 16, 2023 Reactions: 1 users
AeroCoupe lube between the nut and the face Founding Member Oct 28, 2001 2,503 1,457 153 Claremore, OK Mar 16, 2023 #22 Mar 16, 2023 #22 My guess would be that the brake fluid leaking out of the master cylinder at some point is what did the booster in. Glad you got it fixed! Reactions: 1 user
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 41,724 17,315 224 Massachusetts Mar 16, 2023 #23 Mar 16, 2023 #23 I concur. that rust/bubbled area suggests brake fluid was leaking down/into the booster and compromised it. Reactions: 1 user
93CalypsoConvert Active Member Nov 26, 2020 267 80 38 Virginia Apr 29, 2023 #24 Apr 29, 2023 #24 Update. My brake pedal sticks on occasion. It will stick down about a half inch. Its just enough to make me notice. I just put my foot under the pedal and pull it back. Any ideas on what this could be from? I ensured booster rod depth.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 41,724 17,315 224 Massachusetts Apr 30, 2023 #25 Apr 30, 2023 #25 Brake switch installed correctly?
93CalypsoConvert Active Member Nov 26, 2020 267 80 38 Virginia Apr 30, 2023 #26 Apr 30, 2023 #26 No it wasn't. It was upside down. Brake lights operated normally with it in wrong... interesting. I'll update if it fixes it.
93CalypsoConvert Active Member Nov 26, 2020 267 80 38 Virginia May 24, 2023 #27 May 24, 2023 #27 Problem persists. Getting booster warrantied free of charge.
93CalypsoConvert Active Member Nov 26, 2020 267 80 38 Virginia May 30, 2023 #28 May 30, 2023 #28 Re-replaced the booster and now I finally have working, normal feeling brakes. Reactions: 3 users
