Ive been having this problem ever since i put the heads cam and intake on. When i just rev the engine sometimes, as the revs come down it stalls. It also happens when i slam on the brakes real hard stopping quickly. I have no vacuum leaks, i checked that over very carefully. Timing is a 16* and fuel pressure is at 42psi. Spark plug gap is .042''. The cam is was timed straight up when i put in. I still have the stock injectors with a mass air calibrated for them. I'm confused. Other than that the car runs fine.
thanks
tom
see sig for additional mods
thanks
tom
