rocker arm question
  • Thread starter Thread starter mikes mustang
  • Start date Start date Nov 17, 2008
M
mikes mustang
  • Nov 17, 2008
hey i have a 88 and i am puting a f cam in it it has gt40p heads and intake on it and i was wondering if i have to get new roller rocker arms with the roller lifters
thanks mike
Brian@PAR
86
Phoenix AZ
Nov 17, 2008
  • Nov 17, 2008
Are you saying you have roller rockers and want to know if they need to be replaced or are you wondering if you have to upgrade to roller rockers?
If it is the former the answer is no unless they are damaged. If it is the latter then I would have the heads modified for studs and buy 7/16th stud rockers. Do you have to go roller? No but I would not run stock rockers on any cam over stock.
Pedestal roller rockers are pricey and you can't use them if you go to aftermarket heads. Comp Gold race rockers are 259.99 (stud) and thier aluminum pedestal rockers are 289.99 for 3/8 and 370.95 for 5/16th's.
I have no idea what it would cost to modify the heads for studs but it's not a big deal to do so it can't be that much. Of course you have to factor in the cost of the studs as well but you'll be able to recoupe some of this if you sell the heads down the road.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 18, 2008
  • Nov 18, 2008
Brian@PAR said:
Pedestal roller rockers are pricey... thier aluminum pedestal rockers are 289.99 for 3/8 and 370.95 for 5/16th's.
Nah, you can get pedestal rockers for $100 less than that all day long. Summit has Crane rollers for $199 and Proforms for $175. I used the Cranes on my engine.
You can use the stock rocker arms with the F cam if you desire.
M
mikes mustang
  • Nov 18, 2008
i think i am going to use the stock rocker arms cause the motor only has about 40 thousand on it thanks
L
lang williams
567
cleveland, oh
Nov 18, 2008
  • Nov 18, 2008
the stock explorer an mustang rockers are the same.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 18, 2008
  • Nov 18, 2008
Mileage of the engine has nothing to do with the decision of whether or not to use roller rockers. Roller rockers do require less HP to use than standard rockers. You may pick up a few HP that way. They're also more consistant from arm to arm as far as the ratio goes then the stock arms.
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine Parts to pair with GT40P heads?
  • foxbodyclark
  • Jan 23, 2025
Fox 5.0 Mustang Tech Jan 28, 2025
Rcdgl
R
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
