So now...here's my problem...
The fully assembled roller idler arm with all the parts...is too long on the stud that holds the idler...I can't put a nut on it...there is only 1 maybe 1.5 threads visible. I though it might need to squish down so I tried that without the washer on it...and there was not squishing down.
So I bolted it all together without the grease fitting peice. I stuffed it full of good grease and tightened it down
Instructions say 20-30 ft/lbs.
So I made it reltaively tight...since my t-wrench starts at 50 I can't confirm how tight...but its tight...and I just barely got the cotter pin in.
So the question now it...yes when its in vise I turns with moderate effort. But I can't turn it when its not in the vise just by holding on to the mounting bracket. How 'loose' aka 'smooth' is this suppose to be? Yes it turns easier than it did with the bushing....just worried that I have somehow managed to screw something up. ( And yes I just realized it is together upside down, but regardless think it would be ok without the grease fitting? it turns out there are multiple thickness idler arms)
Think it will be ok?
gee....can I say that too?
but seriously i really think your shaft is too short, if you can find the original unit see if the shaft is any longer. good luck
