- Feb 21, 2006
- 573
- 1
- 19
Last weekend I put a 1 inch spacer on my carb and rubber ring on top of air filter base housing to get it to butt up to hood - kind of a ram air set up. Got a little hesitation afterward - increase fuel/air about 1/4 turn out and seemed to run good.
In any case today started up car - choked kicked in as normal and starting reving car - all of a sudden before I could blip the pedal to shut off choke it started running rough like it was not getting any gas. As I started giving gas it started blowing some white smoke in back. Took for a ride and and after a couple miles problem gone. Got home and pulling in garage started doing same thing running a little rough and whilte smoke. Rev'd a couple times and now okay. New carbs, lines, pump etc. last year - not sure if spacer a coincidence but been running all spring fine.
What do you think - I'm pretty sure it is fuel related. Fuel filter? Piece of dirt working way out from moving carb around when changing spacer
302, 600 holley, 289 performer, new msd ready to run
