s/c
ras50gt
200
Is the paxton novi 1000 kit as noisy as the vortech v-1? Does anyone have a video or sound clip of a 5.0 with a paxton novi 1000, if so post it up or add a link. The v-1 is pretty loud, I do like that you know there's something under the hood. I have read that the kits are basically the same but the paxton comes with a thicker bracket, any other differences and also opinions on which kit? What does it take to get between 6-10 psi out of these kits? Thanks
V-1 SC-trim Vortech and Novi 1000 are BASICALLY the same blower.
Both flow the same CFM and come with the same stock boost.
The novi, however, comes with an aluminum discharge tube where as the vortech comes with a cheap plastic POS. (I HAD one).
All in all.. Stock for stock. The novi 1000 is good for about 2 tenths more than the vortech at the track. (this was tested by Blue Oval Performance on the same car back to back only switching the blowers). The only thing they could come up with was that the metal discharge tube was larger and smoother thus allowing more air to move fast into the engine.
making more psi is as simple as spending 65 bucks or so on a new pulley and about 1/2 hour installing it.
I bought the vortech... no real regrets.
The novi is a real strong performer... you really can't go wrong either way.
Just stay away from the powerdyne/ford racing blowers. They max out quicker, have less potentional, and have a dedancy to break belts.
