Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Thread starter Thread starter Sask84gt
  • Start date Start date Oct 13, 2025
First Prev 2 of 2
Sask84gt
24
22
Canada
Jun 6, 2026
#21
  • Jun 6, 2026
  • #21
AeroCoupe said:
Right where it is now. Mark where the rotor points on the distributor and mark the base of the distributor and the block so it goes back where it was. When you back it up one tooth you will feel it. Drop it back down, verify the marks on the base and block, and the rotor should be pointing just behind the mark you made for it.
Thanks for the help. I just said screw it and started over. I needed to learn to do it anyway lol. I pulled #1 spark plug, plugged it with paper towel turned motor over by hand till it shot out, from there I set balancer to my original top dead center mark of zero and restabbed it. Started on first crank and set timing to 18 advanced which is what was recommended to me from the guy that recurved my dizzy. Seemed to all work out. Thanks all for the info.
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Jun 6, 2026
#22
  • Jun 6, 2026
  • #22
Did you disconnect your Vacuum advance while setting timing??
I like to crank my balancer to 10 degrees advanced so when I set the distributor its a bit closer for start up..
Reactions: Sask84gt
Sask84gt
24
22
Canada
Jun 6, 2026
#23
  • Jun 6, 2026
  • #23
Yes I did
First Prev 2 of 2
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
F
1990 mustang GT, essentials to making a 5,000 mile round trip (Michigan to California, and back)
  • FreeMustangProject
  • May 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 14, 2025
hoopty5.0
94 Gt to 84 Fox
  • 351C-84'Fox
  • May 16, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2024
351C-84'Fox
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
