I've been having trouble with my rockers the setup is as follows: Heads machined for 7/16 studs, 1.6 roller rockers, hardened pushrods, comp cams, guide plates, stock hydraulic lifters.
I know the "plain" way of doing this is tightening the rockers until the pushrods start to tighten (by turning them with your fingers) and then turn the rocker nut by 1/4 or 1/2 turn and lock into place and ZERO valve lash.
My problem is that I'll either end up with a loose valvetrain which ticks like a diesel (and not run properly since the valve timing is off) or one or two valves stay open causing my engine to run on 6 or 7 cylinders. Good thing I can remove my valve covers WITHOUT having to remove the upper intake.
I went and got a dial gauge and magnetic base so I can adjust the lifter preload properly, I'm not sure what the preload should be; is it .020??? Or should I put the dial on the valve to watch and make sure the valve doesn't move while I attempt at turning the rocker nut 1/4 or 1/2 turn? The lifters will be charged since the engine would have run a couple of minutes prior to removing the valve covers.
I'm going to try and find the correct preload and attempt that and if THAT doesn't work I'll try the old school way of adjusting the rockers with the engine running
