sct maf 2400
ADRENLN
2,342
NJ
why do all the adds for this meter say:
Supports 400rwhp - 575rwhp with Centrifical Blower Applications
Supports 400rwhp - 650rwhp with Roots Blower Applications
why does it support less power on a centri blower? i figured it to be the other way around.:shrug:
sorry, i was wasted when i started this. its the sct maf 2400.
that might help get a responce.
im just wondering if i should get the 2800 if i ever decide to raise boost. i know im going to get an aftermarket intake so that will bump power too.
the 2400 and 2800 are history now. there was a problem with SCT using fords meter housings.i thinkit was a bunch of legal BS!
SCT BA-3000 90mm MAF Meter
Supports 400rwhp - 725rwhp with Centrifical Blower Applications
Supports 400rwhp - 825rwhp with Roots Blower Applications
SCT BA-2600 90mm MAF Meter
Supports 400rwhp - 625rwhp with Centrifical Blower Applications
Supports 400rwhp - 700rwhp with Roots Blower Applications
to answer your question i believe the are using the meter as a blow thru on a centri. thats why it handles less power.
personallyi have a 2400 on my car now and i will be swapping to a sct3000 in the future
oh, thanks man...very useful info. i was unaware of the switch even!
it seems like the 2600 will handle my power levels......what type of power are you going to put down that you are going with the 3000?:jaw:
i think you can make the 600 on just the blower 2.8 pully alone. i dont even think youll need the 10% OD crank pully.
im hoping to crack 500-530 rwhp with my set up in a month. if i were to go to 2.8 blower pully and get the p51 intake that should get me pretty darn close to 600 rwhp i would think.:shrug: i will have the 3.0 pully on the novi this time around. im not touching the crank pully.
what compression is your engine?
i havent bought the pistons yet so i'm not sure. my car seems to not make boost like it should. i am only at 10-11 psi with a 3.2 and my IC.i'm not taking any chances withe the new engine not making enough!
