I'll add one more thing that I've learned lately. Best corning control requires a "square" wheel setup. By that I mean whatever you run up front you need to have in the rear. Same width wheels and tires all around. I say that because if you can only fit a 17x9 with a 275 tire up front then that's the widest you should run in the rear. Having narrower wheels up front and wider in the rear will make for a loose front end because the rear will have more grip. So don't get too carried away with tire clearance in the back because it's limited by what you run up front. This of course depends on how serious you want to hook in turns.
You're absolutely right and I should have mentioned that as one of my goals. I'm really aiming at the possibility to run 305-315s front and rear. I used to have a staggered setup on my 95' Cobra, and it worked well, but that's because at that time I was running a mainly stock suspension on the track and was trying to compensate for other suspension deficiencies. Only if I was switching to a SLA front end would I have considered a staggered setup with a SRA rear setup. I think it might be obvious at this point I want this thing to corner quite well. I'll mess with other items, other then the tires, if I don't like the handling balance I achieve.
Lets keep this "kid" talk out of this thread, I've been dodging that bullet for 20 years and don't need to give her any ideas.
